Heads and cam for a 4.8?
I have a 2000 4.8L, 168k on the clock. I use it as a daily driver and want to give it a little more power. Since the 4.8L is a little smaller than the 5.3L i'm not sure what to go with.
What heads and cam would benefit this motor for a daily driver that I want decent amount of power, is 400-430 horsepower realistic? Looking for recommendations on a heads and cam package.
Start with a 6.0L. Cannot stress this enough.
The following sentence has been edited to take into account 33" tall tires.
4.10 if highway MpG is most important. 4.56 if city MpG is most important. 4.30 to split the difference.
Do the above before considering a cam or torque converter.
If you insist on a 4.8L, then supercharge it as suggested. Not worth camming a 4.8L.
Sure.
But not at the same time as pushing around a truck. Things that you can do to increase HP by that much (other than The Force of whatever variant) all will cost TONS of low-end torque. Which is what you need most, especially since you have terrible gears and a stock torque converter. Increasing HP will make the truck SIGNIFICANTLY slower as a daily driver.
The loss from this will be greater than any gain you can get from any increase in flow, which isn't needed anyway because of the small displacement. A cam is the poster child for loss of low-end torque. There's nothing to be gained, in a daily driver with that engine, from either of those.
OP: To really get anything out of the 4.8L you would need to put in heads and a cam, plus full exhaust and a tune, and that's at a minimum. YOU CAN GET THAT POWER GOAL YOU ARE WANTING, but not until over 4k RPM, and you're not going to change that on a 4.8L. If you have a manual transmission, then this is an option. If you don't, then this is silly, and you wouldn't get anything out of it except at the track, and when you're passing someone.
For a daily driver, and about the same cost, you really want a 6.0L. It will drop that 4400ish powerband down to about 1500rpms and actually be usable in a daily driver. You would spend about the same, and you wouldn't get as much up top, but you'd get close, and you'd get a lot more in the first half of the tachometer that you're not getting now or wouldn't get after anything you would do to a 4.8L. If you want to keep going after that, you can go well past your goal easily with a 6.0.
I have a 4.8 in a heavy pig with 35 x 12.50 R20 10 ply tires...
Runs strong with 11PSI BOOST spinning 4.56 gears.
Stock cathedral heads will pass plenty of air for that little mouse motor.
Mine has a "LowLift" Texas Speed cam. 212/218 duration, .550"
I have a 2000 4.8, 168k on the clock. I use it as a daily driver and want to give it a little more power. Since the 4.8 is a little smaller than the 5.3 im not sure what to go with. What heads and cam would benefit this motor for a daily driver that I want decent amount of power, is 400-430 horsepower realistic? Looking for recommendations on a heads and cam package.
TheDreamSICKle
Jun 28, 2005 05:54 PM
68c10owner
May 5, 2005 10:49 AM
