Heads and Cam
Old Jun 7, 2002 | 06:48 AM
Default Heads and Cam
As alot of you know, im running a magnacharger on my 5.3L. Im also running 8.1 injectors. I want to do a cam and heads next, but I need recomendations on what size cam, and heads. What should I use to tune it with? LS1 Edit?
Old Jun 7, 2002 | 07:07 AM
BigTex's Avatar
Default Re: Heads and Cam
The easiest thing to do may be put a set of stock LS1 heads on. Those should lower your compression ratio to just under 9.0:1 which would be good for a supercharger. Also, those heads will give you larger valves stock than the 5.3 heads have.
GrooveCityZ71
Aug 31, 2015 12:05 PM
JFortner5
Aug 12, 2015 08:46 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
Aboss
Jul 9, 2015 10:28 AM
