Heads?
Sexy Party Mod
Alrighty guys. I need some opinions and/or help. Since i am having to wait till the end of the semester for a cam, i have decided to go all out and do some serious stuff. I will be getting a custom grind cam but havent decided what to get yet. Im thinking of giving futral a call but not until i get the ok from the old man in May. The truck is gonna run NA with a chance of gas but not FI so maintaining the stock compression ratio or raising it is gonna be a key factor. so the 2 34 dollar questions is:
Aside from the LS6 heads, (cast # 243) What LS1 production head is the best performer out of the box after bringing it to stock compression? (please give me casting numbers)
Is it worth it or should i just stick to the stock 5.3 heads, have them milled a bit to up the compression, and get the whole Port and polish business out of the way?
Thanks for reading!
Thanks for reading!
Sexy Party Mod
oh sorry for the lack of info about that! I was looking to spend less than what i was seeing the prices at. The lowest i have seen those for is $500 and that is a little much for a college student. If i could find some for $300 then that wouldnt be a problem because i would have them milled and be done with it. If that were out of the picture i was thinking cheap!!! What would be the cheapest and perform better?
Sexy Party Mod
Originally Posted by 02sierraz71_5.3
I would mill the heads .050 and run something like LPE gt2-5 222 .566 112, hope youve got a stall.
Just get your stockers milled a little and replace the lifters while ur in there since you will have the heads off. A 222 duration would be decent and throw an LS2 timing chain on there springs, and replace the valve guide seals sicne you will have the springs off.
Sexy Party Mod
Sexy Party Mod
Originally Posted by v8
well if you shave off .050 then you will have to do the intake side as well, then you have to worry about valve to piston clearance, good luck
Btw Kevin, what is goin on with your head swap? How much are you shaving them and such. What compression ratio are you gonna be running? You got the 853 castings right?
17,16,15,14,13,12,11 Drvr
heads are still in the living room lol, going to take them friday to get milled another .020 for a total of .033, I have the 853 correct, I hope to get them installed before the 19th of march, have to get a few things like lifters just because im there lol,gasket kit, waiting on arp bolts if they dont get here in a couple of weeks i guess i will have to buy some.
03regcab sierra
Sep 9, 2015 02:02 PM
sauldgold
Jul 23, 2015 02:15 PM
