heads???
Old Dec 14, 2005 | 11:00 PM
Grumpy5.3's Avatar
Default heads???
I have a 4.8 rcsb sierra, would it be worth the time and money to switch heads, for some say Ls1 aluminum heads??? If so what heads should i be looking for??? and what are the casting #s???
thanks guys
Brian
Old Dec 14, 2005 | 11:33 PM
PappyDan's Avatar
Tribe Shaman
01 - 04 ls6 210 / 75 64 cc should work just fine
Old Dec 15, 2005 | 12:21 AM
8ALTNG's Avatar
Well it depends on the other mods that you are going to do. Are you doing forced induction , spray or n/a??? are you going to get a cam??? a stall???? what are your current mods??? what are your power goals?????
Old Dec 22, 2005 | 09:49 PM
ChevyTrukRacer99's Avatar
If you put actual LS1 heads off an f body will they just bolt up and all the brackets for accesories like up correctly? Just wondering...
Old Dec 23, 2005 | 12:01 AM
Richard@WCCH's Avatar
FormerVendor
The center bolt LS1 heads are externally identical to the 4.8l, 5.3l and 6.0l truck heads. The major differences are in the intake seat/bowl area and the combustion chambers. All brackets will interchange without issue.
Richard
lsxmalibu
Sep 9, 2015 11:08 PM
03regcab sierra
Sep 9, 2015 02:02 PM
axekick
Sep 7, 2015 07:01 PM
sauldgold
Jul 23, 2015 02:15 PM
Aboss
Jul 9, 2015 10:28 AM
