Headlight Problems....AGAIN...well, actually...STILL !!
Originally Posted by 02Reaper
just had the problem appear. I took it to the dealer and they didnt know what was wrong with it because by the time I got there the truck had warmed up and it had stopped. They checked the battery and alternator anyway and said that everything was fine. Well It was still happening the next morning (only cold mornings) so I bought a new alternator, no fix. Then I got a new optima battery, no fix. Went back to the dealer and said look something has to be done. They told me after my truck came in they had 2 other occurances, one of them they actually tested while it was happening, they said everything checked out. They told me they called GM and they had started to have the problems mainly up north. Right now there is no fix for it, gm told them it was the alternator regulators charictaristics and that they could change everything around the alternator and battery and it still wouldnt fix it. SO the dealer has to make a case, and now we have to wait for them to come up with a solution. It affects any 99-2003 truck/suv right now. They didnt know why it automatically started doing this now instead of 99, and 2000, 2001. They said that the engineers were working on it, and to check back every week or so until they have figured it out.
Ill let you know if I find out anything else. You do need to go to the dealer even if the truck is not under warranty anymore and start a case, that way they wont be able to say just live with it. They will be forced to do something with enough complaints.
Originally Posted by LOW2000
Sounds like a faulty ground.
Originally Posted by Black Blown 02
The voltmeter needle dips about 1/8'th inch when the lights dim also.
But the alternator could still be fine, and something is just drawing current, right??
Sounds like a ground problem. Either lack of or not a firm contact, or something grounding out. One that sounds like it may become worse with moisture. Grounds are not easy or fun to find. Anyone have the wiring diagrams for their truck and a meter?
