Headers on the way
Tons of tips and info for you right here:
https://www.performancetrucks.net/fo...d.php?t=450962
rel3rd is right. the only way you might be able to see a difference is by putting the truck on the dyno. Even on that, it all varies with your exhaust set up and so on. You cant just bolt them up and expect to feel a difference in hp just because its a different brand. Although you may be able to feel a slight difference from stock to aftermarket or shorties to long tubes. just my two cents.
they bolt up directly to your stock cat-back. you cannot keep your stock y-pipe with these, but if you read the link rel3rd posted i think somebody said the resonators act just like cats
no it wont bolt up. if thats the case then maybe you should find a set of shorties instead of longtubes. But you should be good to go with the long tubes considering it comes with resonators that replace the cats. Also replaces the stock y-pipe
Superman09
Sep 25, 2015 05:55 AM
dirt track racer 81
Sep 21, 2015 06:44 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
