headers plaese HELP
Old Jul 15, 2007 | 10:11 AM
slownlow4.8's Avatar
Default headers plaese HELP
went to put my headers on today and they are hitting the cross member, on the box it has 4WD so are they not going to work
Old Jul 15, 2007 | 11:12 AM
black2003ss's Avatar
1. What brand headers?
2. What type of truck?
3. Your drivetrain configuration?
Help us help you...
Old Jul 15, 2007 | 11:26 AM
2001si3rr@'s Avatar
Need more info for sure!
Old Jul 15, 2007 | 03:33 PM
pace setter
03 gmc sierra rcsb
Old Jul 15, 2007 | 03:39 PM
i email sean at speed engineering he said that they may be defected
Old Jul 15, 2007 | 03:50 PM
BlackSS04's Avatar
same thing happened to me with my pacesetters. i took it to my exhaust shop and they bended it a couple of inches to give it more clearence. i haven't had a problem with em since.
Old Jul 15, 2007 | 04:36 PM
99Silver6.0's Avatar
Pacesetters defective.... NO WAY!
Old Jul 15, 2007 | 04:52 PM
so is there any way to make them work, and would bending them be ok
Old Jul 15, 2007 | 05:46 PM
xlcooplx's Avatar
passenger side header? have you tried installing it from the bottom? i couldnt get the passenger side header in from the top as it would hit the chassis. i put it through from the bottom and it slid in. it makes it easier if you remove the oil dipstick. all you have to do is pull on the tube. it has an o-ring around it and removes/installs simply.
also, my box said 4wd as well. no problems though.
Old Jul 15, 2007 | 06:00 PM
agreif's Avatar
if they are ceramic coated I wouldn't bend them. What is hitting, the Y pipe? Too long axially or is the angle of the headers wrong.
