Headers
Old Dec 22, 2003 | 08:11 AM
1LEThumper's Avatar
Default Headers
If you had to get a set of headers for your truck what would you get? I noticed Dynatech just started to offer theirs without the Y pipe, I don't see much use in that since I would want to swap over to true dual exhaust myself.
What do you guys think, or are you waiting for something better?
Old Dec 22, 2003 | 08:47 AM
1BADHD's Avatar
Thorley......best bang for the buck!
Old Dec 22, 2003 | 09:21 AM
FILE's Avatar
Yeah.. as long as they are mid-long tube headers you will fine. TOG, ASM, Thorley Lapole make them.
Old Dec 22, 2003 | 10:31 AM
WhiteDiamond's Avatar
If some of you who reply could also mention whether or not the headers you choose could easily weld up to the factory y-pipe/cats, I am interested in some headers for the Escalade that will weld up to the stock y-pipe/cats.
Thanks.
Old Dec 22, 2003 | 06:12 PM
Brandon Boomhauer's Avatar
White Diamond, check out JSmith's site. At the bottom he has links to fast 4.8 and BigKids sites and a couple others. Most of those guys have headers, some with ASM Long tubes on stock Y and some on LaPole mids...
Btw someone have a link on the thorelys? I just want to see what I missed. My ASMs should be here tomorrow !!!
Old Dec 22, 2003 | 06:56 PM
FILE's Avatar
Thanks.
I had mine welded to the stock Y pipe with no problems.
Old Dec 22, 2003 | 07:01 PM
Flyer's Avatar
I have and would buy again if I could do it over the TOG headers. I would have gotten them coated from the beginning if I were to do it again though. Don't get a header that isn't ceramic coated, you'll run rich and throw codes. I like the build of the TOG headers myself, and they were relatively easy to put in. Cut the factory y-pipe about an inch in front of the cats and have the collectors welded up there.
Old Dec 22, 2003 | 07:03 PM
Sport Side's Avatar
how much do the thorleys run?
Old Dec 23, 2003 | 02:47 AM
onyx's Avatar
14 Second Truck Club
i'll be going with clear image full length tri-y headers... they have proven performance...
http://www.clearimageautomotive.com
Old Dec 23, 2003 | 07:05 AM
2001si3rr@'s Avatar
TOG's for sure no questions. They will work fine with your y-pipe set up.
