Header leak
Old Jul 24, 2013 | 09:25 AM
EscaladeEXT's Avatar
I did the job and it wasn't too bad, although my problem did no go away so I snugged the bolts up to 20 ft lbs and it definitely didn't make things better, maybe worse. I am just having a hard time determining where the leak is coming from.
Is there an easy way to search for exhaust leaks? Adding smoke somehow or something?
Old Jul 24, 2013 | 06:06 PM
batboy's Avatar
11 Second Club
Usually it's obvious where the leak is if you look at the old gaskets.
Old Jul 24, 2013 | 08:22 PM
Ok found it, small hole in header pipe. I have dynatech long tubes and there is a hole at the weld on one of the pipes. Now I really don't want to buy new headers as I'm sure I won't find the exact same ones locally and the exhaust will need to be modified. I think I will attempt to have it welded. Not sure how that's going to pan out. Thanks for all the help thus far!!
Superman09
Sep 25, 2015 05:55 AM
creekrat
Sep 10, 2015 12:59 AM
custm2500
Sep 8, 2015 05:53 PM
mr03silverado
Sep 2, 2015 11:43 PM
