Header install questions
I used the ones that came with the headers. about a week later they blew out and I put the stock one's back in. Haven't had a problem since.
i just installed the LTs with the gaskets from the kit and they leak pretty bad. i will be purchasing a set of stockers to do it again. i called my local chevy dealership and they said they were like $14 ea. so nothing serious.
ya thats about how much i figured they would be.
I used the gaskets that came with my pacesetters. No problems at all. TIPS: get the truck on a lift. Drop the trans crossmember for the Y-pipe as a whole. Put ur front O2s in. Dont **** with the steering arm, u dont need to. Drop everything thru the bottom and put both headers up from the bottom. Its a piece of cake. Make sure ur careful with the dipstick too, u'll weld it to the block if u dont unplug ur battery. I had to use an impact on my y-pipe cuz a bolt was stripped in the manifold-y connection. Good luck
Dustin
