Header Brand Suggestions
Old Dec 19, 2004 | 10:33 PM
  #21
99Silver6.0's Avatar
Originally Posted by Tiburon
I really hope someday we will able to buy long tube ceramic coated headers for our trucks for less than $500.
Im pretty sure Thorley does. Thats why im looking at them. Or are the Thorleys calssified as mids?
Old Dec 19, 2004 | 10:56 PM
  #22
LVSTOGOFST2002's Avatar
I'm from ct, and you said you are in the middle of design right? do you have that program where you take a user's ride, and use it for design? if so i'd be willing to participate. 2004 5.3 2wd auto
Old Dec 19, 2004 | 11:09 PM
  #23
FILE's Avatar
I think they are long tube headers but I am not sure you can the ceramic coated ones for less than $500.
Old Dec 20, 2004 | 12:01 AM
  #24
I got ya. I went and looked and they are listed $546 on Summits site. I got some coated ones locally for $489 through a friend. I hope they work out alright.
Old Dec 20, 2004 | 08:09 AM
  #25
nativetexan's Avatar
13 Second Truck Club
I'm waiting for that day as well...
Old Dec 20, 2004 | 07:36 PM
  #26
Todd@AZPowerAndSound's Avatar
Dynatechs all day. Based on the install, and performance I say it cant be beat. We did some back to back dyno testing on my truck with 3 different headers...and the Dynatechs really pulled away in the midrange and had a slight bit more up top than the 2nd place header
Old Dec 21, 2004 | 01:50 AM
  #27
Default Great Information
hey Todd....thanx for that last info. That's the kind of info I need. So...I guess....are these Dynatechs a long tube design? And...what Kind of install time am I looking at? Do they ship with all needed gaskets, studs, nuts and so on, to complete the install?
Now, I guess....I ask....do you guys sell this brand? Or do you suggest who I should order from? What's the cost?
Old Dec 21, 2004 | 09:48 AM
  #28
I f you thave the money, id go with jba headers, easy bolt on,i felt the differnce right away,ihave the stainless steel, i paid about 700 for mines.
Old Dec 21, 2004 | 10:06 AM
  #29
Scream's Avatar
MOOBIES Moderator
Originally Posted by Quick Time
Its a tri y design. They will be similar to our C5 tri y.
::taps foot impatiently::
Old Dec 21, 2004 | 12:34 PM
  #30
p3nfo's Avatar
Hey Parts Guy,
Dynatechs are a long tube design. I love mine. They installed with help of a friend in about 8 hours. Might have taken a little less but we had to do some cutting on the stock exhaust because I couldn't get some of the bolts to break loose. The system for the 5.3 comes with a Y-Pipe but I got the one for the 6.0 because it has no Y-Pipe and then I had a custom true dual exhaust fabbed up. Runs great and sounds awesome. I've been getting a couple SES lights - too lean - but my tune from Allen Nelson is supposed to take care of that. The clearances are REAL tight under the truck. A problem I ran into is that the header on the driver's side is rubbing the U-joint on my front drive shaft when I have 4 wheel drive engaged. I called the guys at Dynatech and they said they knew they would be close but they designed them this way so they fit the 2WD and 4WD. They told me to just get under there with a monkey bar and bend the things out away from the joint. Hope this helps.
