head swap
head swap
hello I gotta a 05 avalanche 5.3 and I bought some 243 casting heads off a vette and I read from a tech book that they should be milled at least 0.030 due to lost hp and compression and then I heard that it didn't matter and someone told me today they should be milled I was just wondering if anyone has had this situation or if you know anything about this?
pm richard@wcch, he'll know the exact specs.
I know that 243s were 10.9:1, or something close to that. if you take of the 5.3 heads (which are at 9.5:1, i think) I still think you'll be close on the CR.
Originally Posted by colyneedsv8
243's have 65 cc chambers and 5.3's have 61 cc chambers. You'll need to mill quite a bit to even get back to stock compression.
you can get ported 5.3's for like $1k now. These will easily outflow 243's and you could have them milled at the same time and run like 10+:1 compression. I just dont see the advantage of running 243's on a stock piston 5.3.
