head ?'s
Old May 14, 2005 | 01:05 PM
closet red neck's Avatar
Question head ?'s
Wondering, what heads do ya'll suggest to install on my truck? I am wanting to keep it an all motor truck and am going to install a comp cams (part #54-426-11), lifters, push rods, springs, roller rockers etc........plus everything else in my sig....I only want to spin my motor in the neighborhood of 6200-6500rpm's. I have a 5.3. I don't think I will add any power adders but things might change later. Thank you all for yall's input!!!!!
Old May 14, 2005 | 10:13 PM
02sierraz71_5.3's Avatar
If I had to do it again I would go with a stage 1 or 1.5 from any reputable name make sure to have at least a 3 angle valve job and I would mill at least .030 wouldnt go over .055 depends on what cam you want to go with or if your adding higher ratio rockers. have the cam ground to match the heads, stall, gears etc..
let us know how it turns out
Old May 16, 2005 | 10:13 PM
Will do, thanks for the info!!
lsxmalibu
Sep 9, 2015 11:08 PM
03regcab sierra
Sep 9, 2015 02:02 PM
axekick
Sep 7, 2015 07:01 PM
sauldgold
Jul 23, 2015 02:15 PM
Aboss
Jul 9, 2015 10:28 AM
