Head Gasket question
Old Nov 22, 2018 | 09:19 AM
Ecrod103's Avatar
Default Head Gasket question
Good Thanksgiving day forum members,
Rebuilding my LQ4 to be punched 030 over and not sure which head gaskets covers the bigger bore correctly?
Old Nov 23, 2018 | 06:24 AM
Ecrod103's Avatar
Anyone?
Old Nov 23, 2018 | 07:52 AM
03sierraslt's Avatar
Do you want GM or aftermarket?
Old Nov 23, 2018 | 03:09 PM
Ecrod103's Avatar
Prefer GM MLS offerings.
Old Nov 23, 2018 | 03:12 PM
arthursc2's Avatar
LS9 is hard to beat for price and performance, provided your block and heads are MLS capable.
Old Nov 23, 2018 | 03:34 PM
Ecrod103's Avatar
Its a LQ4 am rebuilding which will be bore 030 over. I'll be utilizing the original 317 heads until i can upgrade if needed at a later date. Am concentrating on a good bottom end which will include a Wiseco pro tru piston kit. Not sure which head gasket to use due to the new bore size and i'd like to be at pump gas compression ratio.
Old Nov 23, 2018 | 05:08 PM
Well what cc pistons? How far out of the hole? 317 head is basically 71.5cc
pump gas as in 93 oct? What’s available near you.
Old Nov 23, 2018 | 08:12 PM
Ecrod103's Avatar
This is the WISECO piston kit specs, depending on the correct head gasket will determine my compression ratio.
With your recommendation it appears a 10.5 ratio....am good with that if this is the head gasket? GM12622033
Part Number:WISESCO-PTS523A3
Bore (in):4.030 in.
Bore (mm):102.362mm
Piston Styleome, with two valve reliefs
Piston Material:Forged aluminum
Compression Height (in):1.335 in.
Piston Head Volume (cc):-4.00cc
Old Nov 23, 2018 | 10:49 PM
arthursc2's Avatar
I'd run that on pump gas all day. LS2s are 10.9:1 and run pump gas
Old Nov 25, 2018 | 04:03 PM
madmann26's Avatar
Bore (in):4.030 in.
Bore (mm):102.362mm
I would take that with a grain of salt. It’s likely less than what is shown due to the head gasket bore, which is larger than the piston bore and often lowers compression.
A ls9 gasket has a bore of 4.100.
Your compression is likely closer to 10.0:1 but should perform well.
