head cc ??
Old Jul 8, 2006 | 03:53 PM
912jonathon's Avatar
Default head cc ??
what cc's are:
5.3 heads
5.7 heads
6.0 heads
thanks
Old Jul 8, 2006 | 04:00 PM
TexCrew's Avatar
do you mean c.i.? cubic inches?
Old Jul 8, 2006 | 04:06 PM
02sierraz71_5.3's Avatar
https://ls1tech.com/forums/showthread.php?t=213148
Old Jul 8, 2006 | 06:06 PM
Jeff Alexander's Avatar
5.3 61cc
5.7ls1 66cc
5.7ls6 64cc
6.0 72cc
Old Jul 8, 2006 | 06:28 PM
Originally Posted by Jeff Alexander
5.3 61cc
5.7ls1 66cc
5.7ls6 64cc
6.0 72cc
Is that correct for the 5.3, if it is, time to get some 5.3 heads.
Old Jul 8, 2006 | 11:51 PM
closet red neck's Avatar
Yes. It's actualy 61.15 or 61.1something cc's. But the above stated is close enough.
James
Old Jul 9, 2006 | 11:03 AM
gmtechnician's Avatar
so how are people putting on the AFR 205 heads on there 5.3's? they have a 66 cc chamber. i know the flow of the heads are better but you would be losing compression. how does this work?
Old Jul 9, 2006 | 12:56 PM
they mill the head down to reduce the combustion camber
Old Jul 9, 2006 | 01:03 PM
TurboGibbs's Avatar
If you plan on putting them on the 6.0 i'd think twice. The intake valve's are smaller and the ports don't flow as well. LS6 heads flow basically the same as 317's (6.0's). You can get larger valves and ported 5.3 heads though. This is a common upgrade for the LS1 guys.
Old Jul 9, 2006 | 09:23 PM
when they mill the heads down do you have to get a new set of pushrods? or is it not enough to tell?
