head and cam suggestions......
Old Jan 16, 2007 | 07:42 PM
02Reaper's Avatar
Originally Posted by Quik
i know but it has been done before and we had no issues. is it tight? probably knowing thta a Trex is meant for stock motor with stock heads. a ls1 has flat tops and with ls6 heads still with in the stock specs that thunder goes by. its just on a larger cubed motor. i took the chance and it cleard and runs strong
There's a lot more to a cam than just those two specs posted. From my experience, no cam is cut perfectly to specs either, neither are engine specs. While my pistons only came out of the hole .0065, others may come out less or more. Nothing is perfect. Engines have tolerances, some fall high, some fall low, some fall all in between. To play it safe, just because it works for one guy, doesnt mean it will for everyone else. Better to be safe and check now on your particular setup than to listen to either of us and possibly find out the hard way.
Old Jan 16, 2007 | 07:46 PM
Quik's Avatar
5 year bitches!
true, but just saying how it worked for me. could easily work the same for him but also not....chances are it will fit no issues in an application as i spoke of
Old Jan 20, 2007 | 04:24 PM
chevydad's Avatar
lq4's have dished pistons right? so he would/ should be fine even after a .30 mill.
Old Jan 21, 2007 | 03:50 PM
litreddevil's Avatar
Banned
you can shave the heads 50ths with no issue are 100 ths angle mill with no issue
Old Jan 21, 2007 | 04:14 PM
Tahoe6.0's Avatar
Originally Posted by 912jonathon
if i was to put a set of 241's on my lq4, what would the comp. be? the reason i ask is because i have a set laying around
10.2 with .041 gaskets
Old Jan 21, 2007 | 05:36 PM
912jonathon's Avatar
so i could mill up to 100 thousands angle milled without any problems with intake fitment or valve clearance. by the way im going with a 236/236 w/ 600/600 lift.
GrooveCityZ71
Aug 31, 2015 12:05 PM
JFortner5
Aug 12, 2015 08:46 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
Aboss
Jul 9, 2015 10:28 AM
