Which head bolts?
Old Jan 3, 2011 | 06:02 PM
MDI2500HD's Avatar
Default Which head bolts?
What should I use for head bolts? I have almost all my parts for my project, going with 243 heads, Thunder Racing cheater cam, TBSS intake and a 90mm TB. This is all going on an 02 2500HD.
Old Jan 3, 2011 | 06:19 PM
andrew383's Avatar
traveling mod
ARP's IMO
Old Jan 3, 2011 | 07:16 PM
TIM Z's Avatar
11 sec. Truck Mod
I would call and get them from SDPC, they helped me get the correct set for my 6.0. Great knowlegeble guys there for sure.
Old Jan 4, 2011 | 10:07 PM
aaronmc's Avatar
Originally Posted by andrew383
ARP's IMO
x2
I went with studs.
Old Jan 5, 2011 | 12:32 PM
OnyxSilveradoSS's Avatar
the GM parts counter will have studs too, there is a post about what they are from.
Old Jan 5, 2011 | 01:35 PM
Mangled03gmc's Avatar
Baltimore Whore
Arp's for sure, get the reusable ones. You want the ones that are different length.. Ones in 05 up went to 2 all the same size
Edit--- Wrong info at first
Old Jan 5, 2011 | 02:29 PM
moes04silverado's Avatar
another vote for ARP - studs!
Old Jan 5, 2011 | 02:35 PM
TXsilverado's Avatar
Arp's for sure, get the reusable ones. You want the ones that are all the same length IIRC.. Ones in 05 up went to 2 diff size's
please explain...i have a 05+ LQ9 and havent heard anything about redesigned head bolts. does each head use a different length bolt?
Old Jan 5, 2011 | 03:03 PM
Baltimore Whore
When I ordered mine, they told me there were 2 diff part numbers, that I needed the ones with the shorter bolts..
1997-2003 10 long and 5 short
2004 + all 15 bolts are short
Old Jan 5, 2011 | 03:36 PM
KLUG'S SS's Avatar
FormerVendor
I found this out some time ago the hard way, spent some $ on a good set of head bolts for my 03 well because of a little mishapI now have an 04 engine in my truck so I am putting the heads back on and I am saying to myself wait a minute these bolts don't look right. This was right around that time where their wasn't much info at all out their yet on it so I had to make some phone calls and see what was going on.
