head bolt question
Old Aug 7, 2007 | 08:30 AM
white1's Avatar
Default head bolt question
I know they are torque to yield, and not suposed to be re-used, but has anyone actually had any issues from re-using them?
I've re-used them a couple of times (on different engines) with no ill effects
Old Aug 7, 2007 | 09:03 AM
Nick™'s Avatar
cheap bastard... here's a hint, Ron and I found them in stock and for the best price at the Carquest warehouse behind Cortana Mall
Old Aug 7, 2007 | 10:34 AM
xlcooplx's Avatar
please dont reuse them.
Old Aug 7, 2007 | 10:39 AM
mwalls54's Avatar
Need More N2O Mod
i havn't reused them but i have seen peoeple reuse them and then have the head gasket blow out after 100 miles or so.
Old Aug 7, 2007 | 12:21 PM
white1's Avatar
I re-used them on my 5.3, and someone else I helped do a head swapped we re-used his. I didnt have any problems with that, was just wondering if anyone personally knew what would be so bad about re-using them.
I mean honestly whats the chances of something happening? You have 15 (I think) head bolts holding the head down.
Imma try and pick a set up, I was just wonderin
Old Aug 7, 2007 | 12:33 PM
Chevy 5.3L's Avatar
I would not try to re use them.
Old Aug 7, 2007 | 12:40 PM
Derek @ EDO's Avatar
FormerVendor
just buy new ones ******.
BTW when you planning on pulling? tonight?
Old Aug 7, 2007 | 04:05 PM
white1's Avatar
Thats what its looking like since my dawg wants to do it tonight
Old Aug 7, 2007 | 04:25 PM
Yogi Bear's Avatar
Take a coat hanger and bend it a little, and it will return to its original shape. Bend it too much and it will remain bent. That is because you have exceeded the "Yield Strength" of the steel. If you continue bending the coathanger at the same location, it will eventually break.
When you tighten a bolt, it will always stretch some. As long as you don't tighten the bolt too tight (exceeding the yield strength) it will return to its original length when loosened. If you "Torque to yield" the bolt will be permanently stretched, and will never return to its original length. Just like the coathanger, if you reuse the bolt and stretch it again, it will be prone to breakage. Have you ever tried to remove a bolt broken off in the block?
Don't take a chance. Buy new bolts.
Old Aug 7, 2007 | 05:41 PM
white1's Avatar
im using new bolts this time, i was just currious i guess. thanks for that explination though
signguy62
Jul 27, 2015 03:42 PM
bbowerman
Jul 26, 2015 10:57 PM
sauldgold
Jul 23, 2015 02:15 PM
fat tony157
Jul 16, 2015 12:35 PM
