Has anyone experienced a failed stock aluminum rocker?
Old Mar 12, 2005 | 11:40 PM
Default Has anyone experienced a failed stock aluminum rocker?
Has anyone experienced a failed stock aluminum rocker with new higher lift cam and 918 springs?
Old Mar 12, 2005 | 11:45 PM
02sierraz71_5.3's Avatar
i wouldnt worry about the rocker failing as much as the springs or the rocker backing out.
Old Mar 12, 2005 | 11:47 PM
Stroker 1500's Avatar
Im guesstimating that by the icon you have?
Old Mar 13, 2005 | 12:52 AM
mattrem's Avatar
What is the lift on your cam? You can use Harland Sharps, Crane, or Jesels as a replacement. Im don't think there is anything to worry about. The stock rockers are lighter on the nose, helping to prevent valve float. There are alot of people using them without a problem, I spent the money and really didn't need to.
Old Mar 13, 2005 | 12:54 AM
I did a little more research and discovered that the stock rockers are investment cast steel. Phew all that worry for nothing!
Here's the link to the manufacturer for whatever it's worth
http://www.hitchiner.com/HIMCO/moderncasting.html
Old Mar 13, 2005 | 09:33 AM
CF7GO's Avatar
I have it sucks. Bearings were every where. I have a MTI C2 came and the MTI stage 2 heads. So whatever springs they use. They only had 3,000 miles on them too. I now have Harland Sharps.
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
BennyB
Aug 1, 2015 08:48 AM
maxspeed05V
Jul 19, 2015 07:08 PM
4B11T
Jul 13, 2015 03:48 PM
