H2O / Meth / Alcohol???
What is the difference between running water, meth or alcohol in an injection system? Also is "alcohol" just rubbing alcohol I can get at longs or is it something specific for these systems? I would guess that I would have to go to a speed shop for the meth!!
single digit dreamer
i run 100% meth. your system needs to be designed for strait meth.
i think meth actualy has oxygen in it so it will add a little power just by runing the meth with no other changes. then with the added octane and cooler IAT's you can run more timing/boost. so far i have been able to add 5psi over what i could run on pump gas. for me that apears to be about 90hp. i am prety sure i will be able to add even more boost once i add more meth
didn't really answer your question about diferent alcohols to spray. you might goto a grand national or syclone site and do some searchs, they have been doing the alcohol thing for awhile.
Thanks for the input guys. Think Ill start with water and alcohol and then look into meth when I get the bugs worked out.
