H/C LQ4 vs LS2 stock
Old Oct 18, 2013 | 07:23 AM
06 4.8's Avatar
Default H/C LQ4 vs LS2 stock
Ok guys I've been off here quite a while and on the tbss forum. I have the opportunity to install a lq4 with patriot stage 2 317 heads and a custom cam for my nitrous setup on my TBSS. Guys on the tbss site seem to be pretty partial to sayin the 1.5:1 compression difference I will actually be losing power if I swap the lq4 in. I just don't see how a heads cam lq4 will have less than a stock 400 hp ls2.
Guys, chime in and let me know what you think
Old Oct 18, 2013 | 08:22 AM
Vortec350ss's Avatar
We would need to know more about the heads and cam you are putting in. Its not necessarily a 1.5 compression drop if the heads have been milled.
I also don't know much about the nitrous world. Does n2o like compression?
Old Oct 18, 2013 | 08:33 AM
DTHPROOF's Avatar
Nitrous likes anything, especially compression lol. I'd stick to an ls2 and cam that motor later.
Old Oct 18, 2013 | 09:04 AM
03sierraslt's Avatar
The LS2 is also lighter, why not mod the LS2?
Old Oct 18, 2013 | 09:58 AM
WhiteX's Avatar
yeah you'd be gaining, from what the interweb says, about 100 extra pounds from that block. Plus the LS2 is the ****.
Old Oct 18, 2013 | 11:45 AM
Blackpanther99's Avatar
Cant go wrong either way. Id stick with the LS2 for spray and just get a LQ4 for boost.
Old Oct 18, 2013 | 11:53 AM
TXsilverado's Avatar
milled ported heads on the lq4 would make more power than a ls2...put those milled heads on the LS2 and have even more compression, but possible PTV issues if you run a big cam.
I think there is only a 60lb difference between an iron and aluminum block. and nitrous doesn't give a F*ck what compression you're at...so I say go as high as you can for the gasoline available in your area
Old Oct 18, 2013 | 12:08 PM
Jake99's Avatar
Bolt on/tune ls2 will make 460hp. 9.5cr lq4 with nitrous cam ported heads would be 460-480hp. Id say they would be close in performance in a truck
Old Oct 18, 2013 | 12:17 PM
how much would you have to mill to get 10.5 from the 317 on a lq4 i'm sure you can get them down .040 without any problems.
Old Oct 18, 2013 | 12:55 PM
Jake99's Avatar
I ran the math once, I know it was 9.9-1 with a .020 mill on a lq4. So you could get close with .040
