Going to check out the new Turbo!
Old Jan 17, 2004 | 10:24 AM
  #21
onyx's Avatar
14 Second Truck Club
so... my 3000 stall and my 4.10 gears.. are a nono?... this sucks.
Old Jan 17, 2004 | 10:27 AM
  #22
Black Blown 02's Avatar
Nah, that combo will work just fine.
Old Jan 17, 2004 | 10:43 AM
  #23
onyx's Avatar
reeehhheeeeehhheeeeeeaaaallllllyyyyyy?????... cool. i'm there.
Old Jan 17, 2004 | 10:48 AM
  #24
RChevy4.8's Avatar
So, the 180HP increase is with the smallest turbo, or the upgrade turbo. The price seems a bit better that going with a radix.
Old Jan 17, 2004 | 10:59 AM
  #25
onyx's Avatar
the install at CM is like 1300 i think...
Old Jan 17, 2004 | 11:19 AM
  #26
The standard turbo gives the same amount of power, and slightly higher boost like 9 lbs, and will give you 500 hp at the crank, the upgraded turbos run at 7 to 8lbs of boost, but can support much more air for the future, but with the trade off of larger turbo lag on a 5.3 or 4.8. They are going to go 6.0 with forged internals for there master piece, and run the largest turbo, and are looking into a 700hp at the rear tires truck. The truck I rode in had the largest turbo, a pretty good amount of lag, and about 7.5lbs of boost from watching the boost gauge, but still, damn, it smoked!
They do charge like 1300 for install! Wow!
Old Jan 17, 2004 | 11:25 AM
  #27
parish8's Avatar
single digit dreamer
i am prety sure seth's truck has a t72 on it, they will go all the way up to a T76 if thats what you want, i have a T76 kit coming, i would rather have a T88 but what can you do
Old Jan 17, 2004 | 01:39 PM
  #28
RChevy4.8's Avatar
what would be the aprox gains on a 4.8 with the smallest turbo and a flowmaster exhaust.
Old Jan 17, 2004 | 01:57 PM
  #29
Yelo's Avatar
150+hp....
Old Jan 17, 2004 | 02:04 PM
  #30
Hardtop's Avatar
Nice report Hodgee. That sounds like a sweet setup. Tell you what, a little bit of lag to 2500 rpm may not be a bad thing. It will help you hook up. A ton of torque down low can = traction problems. Turbos like less gear, and I think 3.42-3.73 will be ideal. Parish, it looks like you are going to have one nasty truck.
Bruce
