Gmc Needs Help.
Old Mar 3, 2005 | 08:32 PM
luv4pits's Avatar
Default Gmc Needs Help.
Ok I got a 2000 gmc 5.3 excb with the base sts kit, 43# injectors, nelson tune, Meth inj,high low boost controll,373.posi. This truck ran a 16.20 on my g-tec stock before my posi. Now at 5.7 lbs boost I can only hit a 15.60 at 91mph. Somthing has got to be wrong! Shoulden't it be alot faster than that?
I haven't tried the meth or the high boost since it's probaly not running it's best. What should my truck mph be shifting outta 2nd at, and what should the rpm be? Thanks in advance. Mike
Old Mar 4, 2005 | 02:53 PM
luv4pits's Avatar
Any help or should I post this somwhere else. Thanks
Old Mar 4, 2005 | 03:10 PM
THE TRUCK SHOULD BE SHIFTING OUT AT ABOUT 5400RPM STOCK AND ABOUT 81 MPH ROUGHLY. I HAVE THE NELSON TUNE AND IT IS SHIFTING AT 5700 RPM AND 85MPH ROUGHLY. AND YES THERE HAS TO BE SOMETHING WRONG BECAUSE I AM RUNNING A 15.39 WITH A K&N FIPK AND A NELSON TUNE WITH 3.73 GEARS AND A POSI, IN A RCSB 4WD!
Old Mar 4, 2005 | 05:01 PM
02sierraz71_5.3's Avatar
get a dyno tune
Old Mar 4, 2005 | 08:37 PM
JERRY2500's Avatar
14 Second Truck Club
Something is definatly wrong. I ran 15.90's before the STS and 14.77 @5psi and this was before i put the injectors,ic, fuelpump and 02pcm. I hadn't made it back to the track but i should be in the low 14's. and this is a 2500HD. You need to put it on a dyno and get it tuned.
Old Mar 4, 2005 | 10:38 PM
luv4pits's Avatar
Thanks guys
Old Mar 4, 2005 | 11:08 PM
Bullhead00's Avatar
Take it to a track
Old Mar 4, 2005 | 11:44 PM
shandy294's Avatar
Yeah or can Nelson help you with it. I ran 16.12 shifting manually at 5,700 and was right about at the end of the 1/4 at the top of 2nd. My friend hit 15.56 in his 00 rcsb,5.3,3.55 peg,FIPK Silvy in the other lane. Good luck!
Old Mar 5, 2005 | 10:22 AM
CHAGO's Avatar
wow, that's pretty shitty! I ran a 15.0 in my truck with the stock rims, tune, long tubes, and exhaust.
Old Mar 5, 2005 | 11:16 AM
14.7's with drop in K&N, flow pro muffler, HPP3, and descreened MAF is what i was running 2 years ago.
