GM Truck Turbo Kit Special Spring Pricing
Old Mar 21, 2005 | 10:20 PM
  #21
JERRY2500's Avatar
14 Second Truck Club
Originally Posted by parish8
you guys dont get it. it is easy to brake stall into as much boost as a whipple/radix runs at it's peak, then as soon as you let off the brake and completely floor it you will probably see even more boost depending on where you have it set at.
i see 4-5psi before i even move, 10+psi a split second later.
EXACTLY! It's easy to build boost off the line.
Old Mar 21, 2005 | 10:57 PM
  #22
2toneblown's Avatar
well back on topic, how much for the upgrade to the gt67? How hard is the install and how detailed are the instructions? I am guessing that this will work with a 4 wheel drive?
Old Mar 21, 2005 | 11:04 PM
  #23
moregrip's Avatar
what a rush!
even when your in 2wd?
Old Mar 21, 2005 | 11:08 PM
  #24
parish8's Avatar
single digit dreamer
no idea on that one BUT if your in 2wd with skinny tires like mine your driveline wont see any stress. just a lot of spining.
Old Mar 21, 2005 | 11:21 PM
  #25
moregrip's Avatar
what a rush!
totally, kinda hard to stall it up for a hard launch in a 2wd truck.
Old Mar 21, 2005 | 11:34 PM
  #26
red90cobra's Avatar
awesome kit if I had a gm truck I would definitely get this kit
Old Mar 21, 2005 | 11:35 PM
  #27
red90cobra's Avatar
wouldn't you need a bigger fuel pump for this combo to be safe? Since it comes with 42lb injectors.
Old Mar 21, 2005 | 11:38 PM
  #28
parish8's Avatar
the stock injectors are good for just a little over 300rwhp. the stuck fuel pump is good for around 450rwhp.
injectors are required but at only 5psi a pump isn't. turn it up at all and you would want a pump.
Old Mar 22, 2005 | 10:40 AM
  #29
LivernoisMotorsports's Avatar
LS1TECH, Trucks, Modmotor Sponsor
The install really isn't too bad and the instructions are pretty detailed. I would say if you are mechanically inclined you could install the kit within a day to a day and a half.
It does work with 4-wheel drive.
As Parish said, at 5 lbs. the stock fuel pump and 42 lb. injectors will be fine but at any more than 5-6 lbs. i would recommend a pump.
A GT-42 or GT-67 would require a different flange, however for example you could use a GT-40/67 and it would be a about a $500 upgrade.
Thank you
-Rick
Old Mar 22, 2005 | 10:42 AM
  #30
Originally Posted by mangledgmc03
by the way how long will these kits be offered at this price
The pricing will stay the same well into the summer months.
Thanks,
Rick
