GM Truck Turbo Kit Special Spring Pricing
Old Mar 21, 2005 | 07:53 PM
bud8fan's Avatar
i rest my case
Old Mar 21, 2005 | 09:03 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
What about C.A.R.B. ???
Old Mar 21, 2005 | 09:06 PM
XLR8NSS's Avatar
Adkoonerstrator
With a single turbo it would be hard to get a C.A.R.B. number due to the fact that running dual cats in the stock location is probably impossible.
I don't know if C.A.R.B. does exceptions or not, do they?
Old Mar 21, 2005 | 09:07 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by mangledgmc03
both are good but the turbo will be easier on the drivetrain.I am doing a turbo once i get some more loot.
by the way how long will these kits be offered at this price
Uhhh.
Mr. Sandog's Avatar
I think I know what that answer is....with 49 other states to sell to, it probably won't happen. $100,000 for a sticker is a significant investment to have to recoup.
Old Mar 21, 2005 | 09:11 PM
Yea, I know it most likely won't happen, I was just throwing it out there
Not to get off topic, but I don't get why you have to have the CARB number if it passes the sniffer test. Isn't that the point of smog checks?
Old Mar 21, 2005 | 09:20 PM
desTRUCKtive's Avatar
$$$$$$$CHA CHING CHA CHING$$$$$$$
Old Mar 21, 2005 | 09:24 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by parish8
the problem with a turbo, and this is a good problem, is that it makes soo much power you absolutely KILL your driveline. if you plan on keeping it at 5psi you might be ok for awhile but who would keep a turbo at 5psi?
i am sayin it is good because unless you go all out it is easier because of the gradual pull unlike a screw type blower.
Old Mar 21, 2005 | 09:27 PM
Mr. Sandog's Avatar
I agree, this is a plus and is what the centrifugal blowers have going for them. The stress of off-the-line TQ (from Radix and Whipple blowers) is a killer to driveline parts.
Old Mar 21, 2005 | 10:03 PM
parish8's Avatar
single digit dreamer
you guys dont get it. it is easy to brake stall into as much boost as a whipple/radix runs at it's peak, then as soon as you let off the brake and completely floor it you will probably see even more boost depending on where you have it set at.
i see 4-5psi before i even move, 10+psi a split second later.
