Getting sick of this!
Old Mar 1, 2004 | 02:47 PM
Z71/99's Avatar
Unhappy Getting sick of this!
I dont know if all 5.3s have a seperate belt to the AC compressor but I need some help.
I replace that belt every month, sometimes twice a month and just did it again today. NOT because it wears out at all, but because it snaps off I have no Air Conditioning untill I repalce it. The belts ~$13.00 and I have replaced it more than 15 times. Thats almost $200.00 in the last year !!!!!
I cant leave it anywhere due to the fact its my only mode of transportation.
And I have gotton so good at replacing them I have time myself right at 4 minutes and 30 sec. from start to finish. But I am sick and tired of doing it and was curious if anyone else has had this problem and how you corrected it. Thanks a lot by the way I apreciate all of yalls help.
Cory
Old Mar 1, 2004 | 02:51 PM
bdubb's Avatar
Never had a problem with any of mine belts. However, I did change over to an underdrive pulley about about 15,000 miles.
Old Mar 1, 2004 | 02:54 PM
BigTex's Avatar
Man, I've never had an issue either. I think you have something physically wrong. My 99 Z71 went 70K+ miles with the stock AC belt. I'm sure that there are others here that have many more miles than that on the stock belt.
Old Mar 1, 2004 | 02:57 PM
XLR8NSS's Avatar
Adkoonerstrator
I've never had a problem with mine either. Maybe your tensioner is bad or something.
I rarely ever use A/C though so it wouldn't be too big a deal to me.
Old Mar 1, 2004 | 02:59 PM
onyx's Avatar
14 Second Truck Club
is the pulley for it pinching anywhere that would make it snap?.. maybe a pulley is loose and its rubbing the wrong way... do you get any free movement?
Old Mar 1, 2004 | 03:11 PM
Z71/99's Avatar
Yeah my truck went about 120000 miles before it started happening.
I will definantly check my Pullies and the alignment of the crank pully and Ac pully.
If I cant fix it I will just order an underdrive pully and if that doesnt fix it then I will just keep replacing em' untill I can get a new truck.
Thanks for your quick responces. Ill attempt to fix it.
Thanks again.
Cory
Old Mar 1, 2004 | 03:41 PM
Banned
[QUOTE=Z71/99]Yeah my truck went about 120000 miles before it started happening.
I have a 99 5.3 never had that happen. went 80,000 before belt broke. check alignment and only buy gates or goodyear belts, the others are crap.
Old Mar 1, 2004 | 04:06 PM
Blake @ FMS's Avatar
FormerVendor
i got 80k on motor, no broken belts yet. btw i drive like a grandma
Old Mar 1, 2004 | 04:25 PM
99 2500's Avatar
Have a friend that had the exact problem you described. The problem was the seals on the a/c compressor leaked out most of the oil (the oil is used to lubricate and keep the compressor cool), and when in use it would get really hot and temporarily seize up. This is what breaks the belt. He replaced the compressor and all is well since then.
Old Mar 1, 2004 | 08:54 PM
your problem is the A/c compressor clutch they do lock and snap the belt . You better of with a NEW comp. and do a yearly service this will help your system work better and last longer,specially inTexas heat
