GenI roller cam: Cam walk
Old Oct 17, 2009 | 12:30 AM
  #21
04SilveradoMykk's Avatar
Originally Posted by NoShow
Any progress Mykk ?
Just slowly piecing it back together, modifying things as I go.
My shims idea for the crank position reluctor wheel didn't pan out. The wheel was touching the timing cover, so instead I machined .050" from the back of the wheel so it will clear the chain.
The front lip of the oil pan gasket got destroyed, a one piece oil pan gasket too. Tomorrow I'll drop the pan and install a new gasket.
Old Oct 17, 2009 | 04:31 PM
  #22
The front & top end are back together, tomorrow I'll do the oil pan gasket and set the timing
Old Oct 18, 2009 | 09:44 AM
  #23
Oil pan is just about done, by the time I started bolting it back up last night it was getting to dark to see anything. So I'll pick it up this morning.
I absolutely love how the GMT800's have the crossmember under the engine oil pan that just unbolts from the frame!
Old Oct 18, 2009 | 03:28 PM
  #24
Yay, broken parts...
I put the motor back together, fired it up. Heard a noise under the drivers side valve cover. I found the exhaust rocker on cylinder #5 like this.
I think I'll take the opportunity to get a set of 1.52 ratios instead of these 1.6ers, I've felt the 1.6ers exaggerate an already aggressive ramp rate of the Comp XE cam without any real benefit.
Old Oct 22, 2009 | 10:29 PM
  #25
The new comp 1.52 magnum roller tips
The valvetrain runs alot quieter now, and I lost a little lope at idle. But no biggy.
I do however need to investigate a noise from behind the timing cover, I have a feeling it has something to do with crank position reluctor wheel, the shims or the sensor
Old Oct 25, 2009 | 09:40 PM
  #26
Got her back together
http://www.youtube.com/watch?v=AcYG415DctE
Old Oct 25, 2009 | 09:49 PM
  #27
2005 Silverado's Avatar
SPAM HUNTER
Burn outs are alot easier on dirty road
Old Oct 25, 2009 | 09:55 PM
  #28
them tires be expensive, and I just bought them
Old Oct 25, 2009 | 10:11 PM
  #29
SPAM HUNTER
excuses are like ********...enough said.
Old Oct 25, 2009 | 10:25 PM
  #30
budhayes3's Avatar
PT's Slowest Truck
I used to run them on my 350 powered 71 Camaro, great rockers
