Gen3 to gen 4
Old Aug 17, 2015 | 08:15 AM
Jblake's Avatar
Default Gen3 to gen 4
Hey all. Just had a couple questions hoping I could get answered. I've recently come into getting an L92 from a newer truck. And it will be going into my 98 rcsb (currently set for an lq9 with 6.2 heads/intake and comp cam) I had my harness made from current performance to run the lq9 and a 4L70 with my setup. But came across this 6.2 for a deal that I just couldn't pass on. From what I understand- crank reluctor will be swapped for a 24x. Not going with a converter box. I could use a front timing cover from an 05-06 ls2 along with a 3 bolt cam gear and timing set. Drill and tap the knock sensors holes to fit the gen 3 sensors and extend the wires. Now main question is: if I swap the ring on the crank. Will I still need to run a TCM? Or will my pcm tuned to run my 6.0/4L70 still control the tranny bolted with the gen4 Motor? Is there anything that I'm missing? Thanks !
Old Aug 17, 2015 | 12:47 PM
Gadgetized's Avatar
I'm not sure about the computer. You need to have the valley cover for a GEN IV though.
Old Aug 17, 2015 | 12:59 PM
Jblake's Avatar
Yeah I've got a complete 6.2 sitting on the shop floor waiting to take some abuse just need to figure out this computer deal. Valley cover can stay. Or I get one from an ls2 as well
97_ek
Sep 23, 2015 09:16 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
elir_mn
Sep 19, 2015 11:43 AM
chvy=power
Sep 8, 2015 11:06 AM
chvy=power
Sep 8, 2015 10:59 AM
