Gen IV 5.3 to 6.0 swap info
I'm just curious.
I found a local guy selling a Gen IV 6.0 short block for pretty short money.
Would this be a direct bolt in?
Are all the sensors in the same location?
Do the 5.3 and 6.0 have the same tooth count reluctor wheel?
I'm going to be doing a DOD delete and figured I could put the work into the 6.0 and just pull the 5.3. I'll be able to be a little more thorough with the engine out to.
A true Gen IV will have a 58X crank wheel and a 4x Cam sensor.
You would need a Lingenfelter conversion box If you have a Gen III truck set up. TRG-002 Conversion Box
What would you be putting it in?
pewter00
11
Oct 20, 2023 05:40 AM
FormulaZR
Sep 14, 2015 05:23 PM
No problem!
