Gears
Old Dec 18, 2004 | 07:35 PM
Default Gears
I'm planning on buying 3.73 or 4.10 gears. i have 3.42s. How hard is it to install and can i do it myself? how much would i tell in gas mileage stepping up to 4.10s
Old Dec 18, 2004 | 08:15 PM
KeukaZ71's Avatar
it depends what you plan on doing with the truck. for example, mine came with stock 3.73. i could not even break the tires loose. then i put a yank 3000 TC and i had one wheel peel all the time so i put in Eaton posi, which made a big difference. i still break the tires loose alot and real easy too. here is what i would do:
- 4.10's with Eaton and no TC
- 3.73's with Eaton and TC
Old Dec 18, 2004 | 09:47 PM
i have 3.42s with G80, not really wanting to put in a tc right now. any suggestions on what i should do. thanks
Old Dec 18, 2004 | 10:21 PM
KeukaZ71's Avatar
if you are 2 WD, go with the 4.10's. see if you like it. if not, at least all you have to do is swap the rear gear and not 2.
do you do alot of highway driving?
Old Dec 19, 2004 | 07:08 AM
Breeze's Avatar
11 Second Truck Club
I just installed US 3.90s and absolutly love them. I still havent gottin on it all the way but she feels good and isnt screamin goin down the highway very little whine if any.
Old Dec 19, 2004 | 07:21 AM
one03sierra's Avatar
Formerly one92rs
Talking
is it a daily driver? are you going to keep modding? do you want a good low end grunt? i went to 3.90's. now that i have an 80e i kinda wish i went to 4.10's. but i do love my 3.90's.
Old Dec 19, 2004 | 09:05 AM
its a daily driver, but i like the low end grunt, I use to drive a 454ss and i got use to having some low end. If i switch gears will i have to replace the G80. And i will be modding later on.
Old Dec 19, 2004 | 03:55 PM
Mort's Avatar
I think you just need to change the gears.
Old Dec 19, 2004 | 03:58 PM
any suggestions on which ones to get 3.73 or 4.10 and are there any special tools i need to install them. thanks again
Old Dec 19, 2004 | 09:15 PM
KeukaZ71's Avatar
i never installed gears, but i did do my Eaton. you probably need the same tools. if there are any bearrings, you'll have to get those pressed on. i had to take it somewhere. you probably are going to need a dial indicator to measure backlash since you will be changing both the ring and pinion gears. you don't want too much backlash or too little
