gears
Old May 16, 2004 | 11:26 AM
Default gears
I have 29" tall tires on my truck. What gears do you guys recommend? I don't want to destroy my gas mileage, its an everyday driver. I am currently running 3.42s and spin real bad.(1 tire fire!)
Old May 16, 2004 | 11:35 AM
FILE's Avatar
4.10's and replace that open diff with a posi.
Old May 16, 2004 | 12:48 PM
Hey,I know where you can find a set of 4.10's
Old May 16, 2004 | 05:32 PM
goshawk23's Avatar
Truck addict
Hey Lotsofun, you lookin to offload some 4.10's. gonna send you a pm about them.
Old May 16, 2004 | 06:58 PM
Anyone know where I can get a posi differential? Anyone selling a G80?
Old May 16, 2004 | 08:02 PM
slowprocess's Avatar
Hey John, how much did it cost you total to get your 3.73s put in? Just wondering what a gear swap usually cost, unless you did it yourself.
Old May 16, 2004 | 08:44 PM
Keith's Avatar
Are you a regular cab or extended cab? I would suggest 3.90's for a ext cab and 3.73's for a reg cab.
Old May 16, 2004 | 09:08 PM
goshawk23's Avatar
Truck addict
hey slow, well, bigkid, another friend of mine and i did mine and the only cost were the gears and of course that fluid stuff from GM and some normal gear lube. it was easy to do the swap, but i had help. if you want to do a gear swap, let me know. we can do it for cheap (cost of gears and fluid).
Old May 16, 2004 | 10:38 PM
I have a single cab. I guess I will try the 3.73s. Anyone know where I can get a good posi differential tho? I called a local salvage yard. They told me they had a rear end with a G80 posi and 3.73s with 56,000 on it and they wanted $1000. I told them that they were crazy. I know the Eaton is a good differential but I was wanting to go the cheaper route and get a G80. Can anyone hook me up? What do they usually go for?
Old May 16, 2004 | 10:43 PM
