which gear would be best
With my current set-up i think my 4-10's are working against me....so what gear should i get.......i like top speed.....so something that can reach 130-140 mph in a 3rd gear would be sick.i'm running a 295 tire....and probly 315 later in life. i will be reving later around 6300 rpms when i get the fuel system upgraded.
3.73s with a 29" tall tire should be good to 150mph at 6500rpm in 3rd gear.
I wouldn't go anything lower than that with your type of blower unless you really don't care about off the line power. If not then 3.42s would get you to your desired goal also and an even higher top speed.
see half of on my problem is that my truck spins all of 1st gear and 2nd somtimes depending on how hot the tire is...., i just wanted go with different gears so i could maybe have more tration. and top speed.
have u done ur piping project on ur blower yet....? green
Besides, I still havent changed out the tensioner that is making my truck sound like a 30 year old beater. Im getting behind!!
jtphelps289
Sep 29, 2015 12:00 PM
