Gear help
Old Feb 6, 2004 | 07:06 AM
RED2K's Avatar
Default Gear help
I need to know what backlash setting for these 4.10. It is shifting hard in between shifts. It never shifted like this before. please help, thanks in advance
Old Feb 6, 2004 | 07:14 AM
6gear's Avatar
Most gears have a backlash between .008 and .012. My Richmond gears specified .008.
Old Feb 6, 2004 | 08:04 AM
RED2K's Avatar
These are GM gears
Old Feb 6, 2004 | 12:59 PM
6gear's Avatar
These are GM gears
Backlash should still fall in this range
Old Feb 6, 2004 | 01:06 PM
Flyer's Avatar
I've been told that a shift will be harder with a lower gear.
Old Feb 8, 2004 | 10:13 AM
6gear's Avatar
It will be a lot more noticable, If you have ever put a 4x4 in low range and got on it through the gears you can really notice a difference in the shifting but it has nothing to do with the transmission it is the reduction in gear ratio that makes the vehicle react quicker which gives the feel of a harder shift.
Old Feb 8, 2004 | 12:56 PM
Silvette_02's Avatar
Not trying to insult or anything, but when you set the backlash, make sure your carrier bearings are preloaded. This makes a difference. Also, would be a good time to mark the teeth to make sure your contact pattern is right.
.008 to .012 is a good range. Should be no more than .003 variation though.
Josh Hucks
Idryfly5
Sep 2, 2022 08:55 PM
Oobray
Jun 13, 2022 03:38 AM
blownss27
Aug 14, 2020 08:27 AM
jtphelps289
Sep 29, 2015 12:00 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
