gasket set
Old Jun 2, 2006 | 04:15 PM
Default gasket set
I am looking at a buying a full gasket set. The head gasket is composite and .60. I'm puttin 317 heads on my 5.3. with what compressin ratio will I be with stock heads and this gasket? I am running boost so I need low. Also they want an extra $50 for the 6.0 gead gasket vs. the 5.3. Is there really a difference between the two? I was told that all gen III parts are a direct swap, if thats the case then I would be waisting my $50.
Old Jun 2, 2006 | 07:59 PM
quicksilverado's Avatar
If you use the 6.0 heads you need the 6.0 gaskets. The 5.3 will not work.
03chevytruck
Nov 7, 2016 04:43 PM
chopperloco
Jul 10, 2016 10:45 PM
JordanH
Aug 8, 2015 07:59 PM
Sexyrado327
Aug 2, 2015 04:08 PM
jmarkway
Jul 18, 2015 09:23 PM
