FYI, this is called the deckplate mod for stock air boxes, this will be my cold air..
Originally Posted by unredeemed
First of all when working with forced induction you can throw out all your ideas that ram air or cold air is a good thing. The compressor will negate that cold air effect or ram air effect and only let in what it's capable of. That and the compressor will heat up the air as it gets compressed.
Yes and No.......Any time you can open up the stock airbox to cooler air it is a good thing, it is a well known fact that the stock airbox is restrictive on these trucks. In a FI application, anytime you can improve airflow and quality of air going in you are helping the "compressor". Magnacharger uses the factory air box for OEM quality and emmissions reasons, if you add an open air filter i.e. cold air intake, you will see more boost. Point in fact, the lighting guys, what is one of the first mods they do besides the pulley upgrade? Answer: cold air intake, or openair filter.
BTW, I have the bottom of my airbox opened up, makes a hell of a difference.
i agree, on a system with a bypass valve reducing restriction or a ram air will have a similar affect on an s.c vehicle as on a n.a , maybe not quite as much because of the turns in the s.c plumbing and radiated heat. even though the s.c will heat the air as it passes the cooler the ari is when it's ingested the cooler more o2 rich the air will be when it gets to the cylinder. while i agree different engines benefit more or less depending on the stock restriction, like blownchevy said, cooler, denser air makes more power.
mzoomora
Jan 3, 2016 07:06 AM
00pooterSS
Jul 16, 2015 02:41 PM
