fuel system
Old Jan 24, 2007 | 10:54 PM
southern_chevy's Avatar
Default fuel system
I got a question about how to run my fuel rails. This is going on a vortec 350 with a ramjet intake, with lt1 fuel rails. My plan are to be around 400hp. Can I get away with running the rails in series. I am clueless when it comes to what size line for what. I was thinkin -8 to from the hard line feed to the regulator and then -6 for the return. Will this work? thanks
Old Jan 26, 2007 | 02:36 PM
someone has to know this.
Old Jan 27, 2007 | 12:25 AM
DrX's Avatar
DrX
Series or parallel: http://www.gmhightechperformance.com...third_gen_use/
Old Jan 27, 2007 | 01:14 PM
so would it be better to run -8 or -6 I read somewhere that -6 is good for 550hp I think.
Old Jan 27, 2007 | 01:53 PM
DrX's Avatar
DrX
-6 is probably good depending on system design, but I used -8 supply, -6(stock feed line) return.
Old Jan 27, 2007 | 01:59 PM
Well if I run them parallel I will come off the stock line and Y it to each rail, then come of each rail back to the regulator, and back out the return port to the factory return.
Old Jan 27, 2007 | 02:12 PM
DrX's Avatar
DrX
Sounds good. Should be good with -6 for 400 hp.
RONIN LSX
Aug 10, 2015 04:45 PM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
