Fuel Starving?
I built a Super Charged 383 Stroker for my truck and have a fuel issue, maybe, could be something else in the tune.
I had a small cam and heads in the truck and went VERY conservative on that tune initially before installing the 383, the new motor has not been tuned as of yet but the condition I speak of is one I want to deal with now.
At WOT from a dig the truck shuts off at around 4K RPM's and then re-ignites continuing the WOT acceleration .
Is my fuel pump not keeping up with the demand?
Is the pump not picking up fuel in the tank when the gas is pushed to the rear of the tank from accelerating?
It's a stock pump
Any ideas? Thanks!
Chad
It's a stock pump
Any ideas? Thanks!
Chad
You are asking to ruin that expensive engine by using a stock pump. I recommend upgrading to a walbro 400 or 450 if you are shooting for 700 and under immediately. Its probably a combination of fuel starvation and not enough pump.
True statement to all the above.
We put an even more conservative tune in it while the engine was being broke in. I got 2100 miles on it waiting to get back to the shop to have it tuned before I put the SC on it. I babied it until 1500 miles and I've hit it maybe 3 times since the initial break in just to see what it would do.
Yes to the bigger pump for sure, before I get the SC installed I will upgrade that. I guess then we will see if it still starves or if the "Conservative" tune before the new engine and after is/was the problem.
Chad
Chad
GXPJAY
Jan 27, 2016 11:45 AM
Fast86z
Aug 23, 2015 12:35 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
