Fuel setups
Old Apr 22, 2008 | 12:17 AM
XLR8N's Avatar
Default Fuel setups
Just wondering what everyone is running for a fuel system on thier gen III's. IM looking to upgraded here very soon but don't really know where to start.
Old Apr 22, 2008 | 12:35 AM
thunder550's Avatar
High on diesel fumes
I'm running a twin in-tank Racetronix setup.
Old Apr 22, 2008 | 12:39 AM
XLR8N's Avatar
What is the flow rate for the pumps? Was it a good fit? I've been told that there are alot of modifications to work with a truck tank, is this true?
Old Apr 22, 2008 | 12:49 AM
thunder550's Avatar
They are twin Walbro 255's. The bucket that I put it was cut up pretty good, but other than that and a plug-and-play wiring harness it was really easy do to. My idle pressure is about 52 psi, it's about 62 psi at 3 psi, and at 4 psi when the second pump kicks on pressure jumps up to about 68 psi. I'm still running the stock fuel lines on a return-style fuel system and have not run out of fuel yet on 15 psi on my 408.
Old Apr 22, 2008 | 03:53 AM
04Denali's Avatar
twin 420 external pumps
Old Apr 22, 2008 | 08:00 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
What are your fueling needs? Those last two posers....oops I mean posters are running larger cubes and turbo-chargers. Your fueling needs will not be as agressive on most applications.
I run a single W255 pump in tank, with a magnavolt fuel pump booster but again I am Supercharged.
You will need to choose a system somewhat mated to your consumption.
Aboss
Aug 11, 2015 09:05 AM
Slammed96
Jul 27, 2015 07:22 AM
lxcoupe
Jul 21, 2015 02:12 AM
4B11T
Jul 13, 2015 03:48 PM
