Fuel pump wiring
Old Feb 4, 2008 | 08:59 PM
2ktransam's Avatar
Default Fuel pump wiring
I have a intank 255 Walbro that I want to install in my truck but it's just the pump. Is there anything else that I need? Is the wiring connection different? I have been searching for hours but I can't seem to find a good answer.
Old Feb 4, 2008 | 09:00 PM
Derek @ EDO's Avatar
FormerVendor
yep, you will have to cut and solder your connector to the pump connector.
Old Feb 4, 2008 | 09:05 PM
2ktransam's Avatar
It didn't come with a connector. It came out of a new Land Rover so it just has the connection on top of the pump for a stock plug connector. Is there any way to make this work in my truck?
Old Feb 4, 2008 | 09:42 PM
FormerVendor
You need that! you will splice into the wires plugging into your existing pump and connect them to the connector that plugs into the fuel pump. stuff the fuel pump in your bucket and hook up the fuel line and you should be good to go!
Old Feb 4, 2008 | 09:45 PM
FormerVendor
https://www.performancetrucks.net/fo...walbro+install
Old Feb 4, 2008 | 11:38 PM
CashDudeHomie's Avatar
What's the half circular thing on the bottom left?
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
