Fuel pump question...Need help fast.
Old Apr 15, 2005 | 04:05 PM
03sierraslt's Avatar
Default Fuel pump question...Need help fast.
Ok, with the exeption of you radix guys. I need to know who has installed a walbro pump in a 04 or 05 with a returnless fuel system. ( In tank Pump) I have a walbro gss342 pump for my denali, the walbro pump is about 1/2 inch in diameter smaller then the stock pump, I am trying to figure out what I can do to make it fit snug. I dont really want it free floating in there. Granted the fuel pump sock will help support it some at the bottom. Need some help here please..
Old Apr 15, 2005 | 04:27 PM
BigTex's Avatar
All the pictures I've seen (like the radix install manual) show a black rubber sleeve around the pump.
Old Apr 15, 2005 | 04:28 PM
Ya I know, the radix kits come with that sleeve. When you get a pump from anywhere else there is no sleeve.
Old Apr 15, 2005 | 04:47 PM
CHarris's Avatar
This thread has more info that the one over at silveradoss.com Why not take a trip down to Lowes or home depot and get a piece of rubber to wrap it? I've bought a sheet of rubber that was 12x12 and used it in a similar situation. or just get a strip of fuel hose to lay in along side the pump in the cup. It'll hold it to one side and take up the space. Just ideas...
Old Apr 15, 2005 | 04:55 PM
Well I thought of that but another thing that I dont like is that the fuel pump sock that i have doesnt seem to stay on well, it slides off real easy. Also does anyone know what Rubber hose is rated to be submerged in gas, most will deteriorate and break down fast. I seen somewhere that D10 is what I need?
Old Apr 15, 2005 | 05:22 PM
BigTex's Avatar
If you use rubber, go buy some fuel injector hose thats rated for use submerged in fuel.
If it were me, I'd use the internal hose you just removed from the stock pump to shim the new pump. On the sleeve, I'd bend the ring with pliers to make it fit firm.
Old Apr 15, 2005 | 07:10 PM
CHarris's Avatar
That's an even better idea about the hose from the old pump. Should work very well.
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
