Fuel pump question.
Old May 22, 2006 | 11:46 AM
Default Fuel pump question.
Can I use a inline fuel pump or do I need to drop the tank and replaced my stock one? Also I was wondering which one I should go with.
Old May 22, 2006 | 06:28 PM
Old May 22, 2006 | 07:40 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
What you trying to do? What's the reason for your question?
Gotta give some details.
Old May 22, 2006 | 09:01 PM
well I have 31lb injectors and am fixing to go to 42lb injectors and just want to know if I have to pull the tank or will the inline one pull through my stock pump. Also maybe a few places to find them at. I never have any luck finding stuff for my truck.
Old May 23, 2006 | 04:10 PM
Will a inline fuel pump pull through my stock pump?
Old May 23, 2006 | 08:31 PM
DrX's Avatar
DrX
Yes. It will decrease the line pressure after your stock pump thereby increasing the output of the stock pump. Pump flow rate decreases as line pressure increases.
Old May 23, 2006 | 09:52 PM
Where can i find a direct fit intank pump?
Old May 23, 2006 | 10:43 PM
DrX's Avatar
DrX
Not sure that there is such an animal for an '02 truck. Adding a high flow inline booster pump will probably provide more fuel anyway. Both pumps will be helping each other out. And it won't mess up the functioning of the factory fuel module.
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
