Fuel Pump Problem
Old Feb 25, 2007 | 01:55 PM
Sport Side's Avatar
Default Fuel Pump Problem
I just put in a new replacement fuel pump and I'm having troubles getting the motor to fire up. I think I have just about tried everything, but maybe someone else has an idea. I took out the old pump and put in the new one. I plugged in the 2 connectors and 3 tubes coming off of the top of the pump. When I try to fire it up, it turns over but it wont start. I'm not getting the ''whirring'' sound as if the pump is priming. I hot wired the pump and I can get it to make that famous noise. When you write a new tune or turn the key to the on position, usually you hear this noise. I do not however. I even tried putting in the old pump and it would again not start. No fuses have been blown. Everything appears to be getting power, but the pump will not prime. These are limited amounts of detail, but I really don't know what could possibly be wrong because it is so simple. Any assistance would be appreciated.
Old Feb 25, 2007 | 02:20 PM
onebadrubi's Avatar
Youve checked the simple things like pulling a wire out or bad grounds? Does the pump have any kind of relay?
Old Feb 25, 2007 | 02:30 PM
CHEVRACER83's Avatar
the fuel pump has a relay.... first things first.... turn the key to on, and have a fuel pressure gauge to the fuel rail... did you hoo the right hoses to the right places??? i know it sounds dumb but its happened...
check the relay first... i have seem people replace 4 pump modules thinking they were bad just to notice it was actually a bad relay
Old Feb 25, 2007 | 02:34 PM
Sport Side's Avatar
Where is the fuel pump relay?
Old Feb 25, 2007 | 02:35 PM
you can test it by getting a relay from a small auto parts store..... but asap get a gm one if that fixes it... because we have had major problems with cheap relays going bad quickly
Old Feb 25, 2007 | 02:37 PM
Sport Side's Avatar
Post #4... Where is it?
Thanks for the help bro.
Old Feb 25, 2007 | 02:46 PM
if you look it should be in your underhood fuse block...
Old Feb 25, 2007 | 02:50 PM
Sport Side's Avatar
hmmm the block. okay. yeah, i swapped a new one in out of an '03 truck. guess that's not the problem
Old Feb 25, 2007 | 02:53 PM
another major problem is the power connectors can melt or corrode internally....
Old Feb 25, 2007 | 02:55 PM
the connector right at the pump module.... if you talk to your dealer they should know exactly which connector i am talking about
