Fuel Pump?
You do not need any special fittings or adapters. You will get everything you need to replace the stock pump. It is a pretty simple swap.
Looks to me like you have to trim the bucket if you want the sock on the outside. I don't even know what the sock does TBQH. When I get my pump in, I'll look it over and make the decision of sock inside or outside. Sock inside seems safer, since it won't fall off, but it might cause you to run out of gas faster than if the sock was outside. I just ordered mine through Summit. Can't wait to tear into this!!
ya know i installed 3 warlboros and i dont see were they were stock replacement atr all ,wires had to be cut ,its smaller in circ so if you dont drill and zip tie the bucket itll wobble all over ,and idk y everyone loves em i must be the only person on this site who went through 3 in 3 weeks.after my exp. i just went too an external style pump ,got sick of replacing.and if i need more gas or presssure i just turn the screw on my regulator .just my 2 cents.although i did put 1500 bucks into my fuel system.lol.so i guess as long as you dont have the problems i had with warlboros youlle be good ,just remember if you plan on super modding it later youll needd more than that.the last 1 i had i ran out of gas at 15 lbs of boost.lol,good luck
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
