fuel pressure regulator is very easy to change until....
Old Sep 12, 2005 | 11:06 AM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by fogle04
which vacuum line do you take off?
There should only be 1 line going to it, right on top of it. The fp reg is the round part in the center of the driver's side fuel rail with 1 vacuum line going to it. I believe they stopped using external fp regs in 04.
Old Sep 12, 2005 | 11:41 AM
  #22
chevyerett's Avatar
My truck has trouble starting sometimes. It will start, idle, then die. Mostly when it's hot. Also, when I turn the a/c on the motor surges, like it's idleing then I give it gas(but I really don't), then idling again. All started after the cam install.
Would this qualify as a bad fp reg or it just needs more tuning?
Old Sep 12, 2005 | 12:50 PM
  #23
Fogle07's Avatar
can you put an adjustable regulator in there like you can with the tpi engines?
Old Sep 12, 2005 | 12:51 PM
  #24
budhayes3's Avatar
PT's Slowest Truck
The a/c problem sounds like a tuning or IAC issue. The hot start problem could be either...it's real easy to check the fp reg to eliminate that as a possibility. Pop the hose and check for fuel...you may have to check a few times due to evaporation. When I originally checked mine cold and it was OK, later I took a ride, went to a store and rechecked on the way out and found gas in there.
Old Sep 12, 2005 | 12:53 PM
  #25
budhayes3's Avatar
PT's Slowest Truck
Good question, not sure on that one...
Old Sep 12, 2005 | 01:14 PM
  #26
chevyerett's Avatar
So drive it, stop, cut it off, and if there's fuel in there, it's bad?
I'll have to check it when it gets back from the body shop .
Old Sep 12, 2005 | 01:15 PM
  #27
Fogle07's Avatar
mines been sitting since about 7 this morning and i went out there just a sec ago and it was dry. do i need to drive it first like he said?
Old Sep 12, 2005 | 02:18 PM
  #28
budhayes3's Avatar
PT's Slowest Truck
I would drive it, let it sit for about 5 minutes then check. If it's still dry, then you're probably OK. FP regs leaking on these seem to be fairly common, mine went bad at about 38k (was about 5 years old though), and I remember a bunch of folks at GMTrucks.com were finding thiers leaking a while back.
A dirty throttle body/IAC passage will give you hard start and idle issues also, but mostly when the vehicle is cold.
Old Sep 12, 2005 | 02:19 PM
  #29
Fogle07's Avatar
mine has a little over 90k on it and im sure its never been changed so ill check it after i get home tonight.
wrb002
Aug 31, 2015 12:00 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
