Fuel pressure regulator
Old Dec 10, 2022 | 10:32 PM
Ares2010's Avatar
Default Fuel pressure regulator
Wondering if yous can put me on the right path?
I'm trying to figure out what kind of fuel pressure regulator I need to run with my setup, I plan on going with 90lb injectors with duel pumps in the stock bucket in tank, it's an 07 suburban 5.3 full exhaust stage 3 cam whipple supercharger currently has the stock fuel pump regulator in the tank no return line
Old Dec 10, 2022 | 10:40 PM
FFDP's Avatar
External regulator right by the fuel rail would be a good idea. Even going to a return fuel system would be nice.
Old Dec 10, 2022 | 10:53 PM
Ares2010's Avatar
FFDP, I figured I'd dump the return right back into the bucket and from what I read run my feed to the fuel rail and put the regulator on the back end of the fuel rail this should be good right? Also should I be using a vacuum dependent style regulator? Also thanks for the reply
BuckNasty92
Feb 23, 2020 08:23 AM
outlawz2004
Aug 30, 2009 06:57 PM
teesee150
May 1, 2009 04:13 PM
