Fuel pressure at rail
Old Dec 24, 2007 | 04:08 PM
phasemaster1's Avatar
Default Fuel pressure at rail
I just hooked up a fuel pressure gauge to my fuel rail. With the ignition on pressure read 50psi. With the truck warm and at idle it read 49psi. I always see we should have 58psi. My truck is a 2003 RCSB 5.3 stock fuel pump 90,000 miles. When I get the walbro 255lph will these pressure numbers change?
Old Dec 24, 2007 | 04:12 PM
dirt track racer 81's Avatar
yes and i wouldnt be doin much racing the way it is now
Old Dec 24, 2007 | 04:16 PM
So the pump is bad? Will the filter cause that also?
Old Dec 24, 2007 | 04:24 PM
check your filter and see if you can blow through it..if you cant change it..dunno if that could cause it..also with the motor running pull the vacuum line off the regulator and see if there is any fuel in it..if so the reg is bad..but if good your pump is dwindling
Old Dec 24, 2007 | 04:26 PM
Thanks will check it out trying to get my numbers correct before the new injectors go in. Thanks
Old Dec 24, 2007 | 04:33 PM
Well pulled the vacume line off the regulator while at idle and no sign of fuel. Ill just go ahead and order new pump and get it over with.
Old Dec 24, 2007 | 09:08 PM
DrX's Avatar
DrX
What is your FP with the vac line removed from the FPR? Did you check it with the vac line attached or removed?
Old Dec 24, 2007 | 11:50 PM
Doobie's Avatar
50 psi is acceptable for a flex fuel engine...is yours FF?
Old Dec 25, 2007 | 01:18 AM
tarinitup's Avatar
9 Second Truck Club
I think your pressures are normal. MIne is also 50 at idle but what counts is pressure at WOT. MIne reads 58 at WOT.
Old Dec 25, 2007 | 01:50 AM
Formulized94's Avatar
mine is roughly 55-58 at idle.
