Fuel pressure
Old Nov 29, 2014 | 09:53 PM
Truckshop's Avatar
Originally Posted by ihdude
What's the easiest way to get it lower and what psi should I get it down to?
Put in a smaller fuel pump or re-plumb the fuel system.
Old Nov 29, 2014 | 10:11 PM
03sierraslt's Avatar
Aftermarket fuel pressure regulator and rails, or smaller pump.
Old Nov 30, 2014 | 08:20 AM
ihdude's Avatar
If I put an adjustable fuel pressure regulator, how much fuel pressure do I set it on?
Old Nov 30, 2014 | 09:28 AM
Truckshop's Avatar
45-50 at idle. 55-60 not running.
Old Nov 30, 2014 | 11:04 AM
JohnDaMan's Avatar
Mine is 58 without the vac tube attached while running or 'key on engine off'
Old Nov 30, 2014 | 11:45 AM
George C....'s Avatar
Formerly ScreamingL
what power are you making that you need such a large pump?
looking at the sig seems as a typical 255 would of be plenty and depending on the parts in the 408 a stocker would of kept up
ive pushed stockers well into the low 400 rwhp range and a 255 will support high 500s NA
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
