Fuel Lines
Old Oct 30, 2006 | 07:54 PM
Red_Dragon's Avatar
Default Fuel Lines
Ok so I have an 89 Sierra and my fuel return line has a hole in it and leaks like a ****. My question is where can I get replacment lines? I want to replace both fuel lines because the sending line isn't in good shape either. I wasn't sure wher eot even look for that type line. Thanks for nay help.
Old Oct 30, 2006 | 08:49 PM
Derek @ EDO's Avatar
FormerVendor
replace it with some steel braided line
Old Nov 1, 2006 | 06:04 AM
Red_Dragon's Avatar
isn't regular steel line stronger though? would that affect my pedal feel?
Old Nov 1, 2006 | 02:33 PM
FormerVendor
steel lines would be stronger yes, but if you dont plan on rolling over your lines, braided would be the way to go. Its alot easier to run because of its flexability plus it looks sweet.
Old Nov 1, 2006 | 03:16 PM
Nick™'s Avatar
steel braided is easy to work with. FWIW the newer trucks use a combination of hard lines and the steel braided
Old Nov 2, 2006 | 12:21 PM
Red_Dragon's Avatar
What do you mean by rolling over? LOL my truck uses a combo of braided, hard line and rubber. Just wondering on whatever I get do I need anything special to put fittings on?
Old Nov 2, 2006 | 12:29 PM
Rhino79's Avatar
9 Second Club
You could cut and splice it with rubber line if you wanted, TBI setups like yours only run about 13psi and it won't be much on the return side.
Old Nov 2, 2006 | 03:06 PM
FormerVendor
ohh yea, save yourself some money and buy rubber hose, i was thinking Fuel injection.
Old Nov 2, 2006 | 05:24 PM
97sicksled's Avatar
Replacement lines LMCTruck or CKResto both companies make pretty much anything you could want for OBS trucks.
Old Nov 3, 2006 | 08:52 PM
Red_Dragon's Avatar
How do I put fittings on the rubber hose? Anyways where would I get the fittings, the kind on there look crimped somehow like most any hydralic lines would be. Anyone know what sizes I need?
