Frickin Frackin Tranny
Old Jul 26, 2004 | 12:02 PM
RED2K's Avatar
Default Frickin Frackin Tranny
Well I was at lunch and had to pull out in traffic in a hurry and guess what, a bit of slipage. I i just eased off and took it easy. I guess I will limp it for a while. Anyone know how much a FLP rebuild kit will be? At least I got 80k hard miles on this one
Old Jul 26, 2004 | 12:31 PM
RED2K's Avatar
Well at least I got 80k hard miles on this one
Old Jul 26, 2004 | 12:34 PM
mudz5.3's Avatar
FLP-L4 LEVEL 4 STANDARD KIT (4L60E LT1&LS1 F-BODY/C5) $1995.00
CORE CHARGE FOR LS1 F-BODY 4L60E $600.00
CORE CHARGE FOR LT1 F-BODY 4L60E $500.00
CORE CHARGE FOR C5 4L60E $750.00
CORE CHARGE FOR LS1 TRUCK 4L65E $850.00
PRECISION INDUSTRIES VIGILANTE PURCHASE ONLY FOR F-BODY AND C5
PRECISION INDUSTRIES VIGILANTE WITH TRANSMISSION FOR F-BODY AND C5
GM TRUCK DEEP PAN WITH DRAIN PLUG
PRECISION INDUSTRIES VIGILANTE 10.5" INCH MULTI-DISC (3 PLATE) CONVERTER FOR LS1 TRUCK
$735.00
$679.00
$100.00
$890.00
PRECISION INDUSTRIES VIGILANTE 10.5" INCH MULTI-DISC (3 PLATE) CONVERTER FOR LS1 TRUCK WITH TRANSMISSION PURCHASE $859.00
FLP-4L65E 4L65E upgrade kit which includes- GM 5 pinion front and rear planet assemblies, 4L65E reaction shaft w/bearing, FLP extreme duty sun shell w/bearing.FLP extreme duty input housing with steel sleeve pressed around input shaft splines with machined overun piston to increase strength. $600.00
FLP-L5 4L65E level 5 transmission - Includes GM 5 pinion planet assemblies front and rear, 4L65E reaction shaft w/bearing, FLP extreme duty sun shell w/bearing, and cryogenic treated input & output and reaction shafts. Also includes GM deep pan with drain plug.FLP extreme duty input housing with steel sleeve pressed around input shaft splines with machined overun piston to increase strength. $2695.00
FLP-TC100 TRANS COOLER - 18,000 GVW $60.00
FLP-TGO1 TRANSGO PERFORMANCE SHIFT KIT $109.95
FLP-VAC 1/4 INCH STEEL VACUUM LINE FOR LEVEL 4 APPLICATIONS (EXCLUDES C5) $15.00
Old Jul 26, 2004 | 01:46 PM
Scream's Avatar
MOOBIES Moderator
http://www.kdsperformance.com/torepa4lls1o.html
Old Jul 26, 2004 | 08:46 PM
Flyer's Avatar
Welcome to my hell ... you better do it right the first time. Stick an 80e in there and be done with it ... I hope that's how it goes anywyas.
Old Jul 26, 2004 | 10:29 PM
one03sierra's Avatar
Formerly one92rs
Talking
im still liking my built 4l60e. but i will test it when i begin to spray her.
Wolftrk99
Dec 3, 2015 08:12 PM
sTNT971
Sep 26, 2015 06:27 AM
racedad70
Sep 16, 2015 01:51 PM
JordanH
Sep 12, 2015 12:02 AM
mayko
Sep 7, 2015 12:24 PM
