Ford SVO 42# to GM injector wire harness
Old May 11, 2006 | 08:34 PM
krambo's Avatar
Default Ford SVO 42# to GM injector wire harness
I will be upgrading to the Ford SVO 42#rs and I was wondering if anyone knew a place that sells the pigtails for these injectors (SVO's) that have a plug for the stock fuel injector wire harness for the 03 trucks.
I am just trying to avoid cutting up my wire harness as the typical pigtails are readily available for this application. There has got to be a place that sells these as a plug and play piece.
Thanks!
Old May 11, 2006 | 09:56 PM
Quik's Avatar
5 year bitches!
its not that bad to cut and play i did it and others have also
Old May 12, 2006 | 06:48 AM
krambo's Avatar
Yea, I am not scared to cut her up at all. I am just a little pressed for time right now and looking to save some time with the swap.
Old May 12, 2006 | 06:50 AM
Quik's Avatar
5 year bitches!
like an hour or so to solder the ends on...to give you and idea you can use Fbody plugs, 2.2 s10 plugs that im aware of since i cut up two harnesses to get mine.
also a 30svo injector at ls1 psi is about 36
a 42svo injector should be up around 50
Old May 12, 2006 | 07:39 AM
leftcoast32's Avatar
FormerVendor
Here is a link to a company that sells the pigtails and will also sell just the connectors so you can wire them on you current harness for less clutter. Give them a call and they can hook you up.
http://www.cprracing.com/injectoradpt.htm
Old May 12, 2006 | 08:41 AM
krambo's Avatar
Awesome. That is what I am looking for. I will give them a call and see on availability / price / application. Thank you for the link!
Kevin
Old May 12, 2006 | 09:19 AM
vanillagorilla's Avatar
Just buy the MSD injector clips for like $14 for all 8. No soldering or cutting or anything. It takes about an hour to do, but it looks very clean.
http://store.summitracing.com/partde...5&autoview=sku
D1SCSS
Jan 25, 2016 10:14 PM
mzoomora
Jan 3, 2016 07:06 AM
TimDave217
Aug 24, 2015 04:38 PM
vortecyota
Jul 23, 2015 08:26 PM
